Diesel Forum - TheDieselStop.com - View Single Post - 2001 Excursion Vegistroke Questions
Old 03-29-2008, 11:32 PM   #4 (permalink)
ajohansson
ajohansson's Avatar
Check out Goldenfuelsystems for their filling port on the excursion. That is the only cool thing they have and the tank too but thats about what I paid for on mine. Everything else redone. You should be happy with your V3.
AJ
ajohansson is offline   Reply With Quote
