Diesel Forum - TheDieselStop.com - View Single Post - 2001 Excursion Vegistroke Questions
Old 03-30-2008, 10:28 PM   #8 (permalink)
ajohansson
ajohansson's Avatar
No problem with full a pillar and vision. The only drawback is you cannot fully put sun visor in down position as it hits the top pod. Rarely is this an issue. I also have a tri-guage pod that sits on the under side of dash for my vegoil temp, vaccum gauge and diesel tank fuel gauge. Autometer Triple Gauge Under Dash Mount 99-04 Ford Super Duty 15018
I will be puting an upper pod that goes over rear view mirror for fuel pressure (current gauge is mounted under hood on fpr), volt meter, boost and ???
Good luck with your conversion.
ajohansson is offline   Reply With Quote
