Diesel Forum - TheDieselStop.com - View Single Post - Diesel Site bypass oil filter
Old 03-30-2008, 10:51 PM   #13 (permalink)
Chinookman
Chinookman's Avatar
Originally Posted by detroitfd View Post
Was the new mounting bar the same size as the original except for the thickness? Just wondering what you suggest the length to be so I don't have to use spacers.
Yes the new mounting bar was the same when the kit comes in do a dry fit when you slid under your truck and add about another 2 to 3". What I did was get a piece of cardboard and and a pencil and copied the bolt pattern of the existing holes on the frame; that was the only deviation from the original bracket that came w/ the kit well plus adding another 2-3" helps out too...
Keep in mind that as a nuclear maint. hand I get a bit anal so the1/8" bracket may be just fine for you but for me 1/4" plate steel was mo-bettah..
2003 7.3 CC XLT Sport short box 2wd dark shadow gray ,AIS Intake Kit, MBRP 4" w/3.5" D/P & 5" SS tip;Wicked Wheel ;Ultra Duty Aluminum Diff.cover JNB kit "HUTCH MOD" and Dahl 100 fuel filter. Silverstar lamps,203 T-stat w/Red billet housing. Fumoto DV w/nipple, AIH mod, Zoodad, Amsoil BMK-11 Oil ByPass Kit,fuel reg. shim @ 0.055 for 65-68 psi. Harpooned tank,Hx Mod, Coolant Filter, Po'man's Fx mod,CCV mod & 6.0 tranny cooler! Pull Rite Super Glide 14k Hitch.
Truck stuff, old Chinooks and refueling a reactor
Saved by Grace, not by choice
6 turning, 2 burning-Love the smell of JP-4
CH-47C Super 'C' 73'-75'
Chinookman is offline   Reply With Quote
