Diesel Forum - TheDieselStop.com - View Single Post - Overboost Annihilator vs Boost Pressure Relief Valve
Old 03-31-2008, 10:27 AM   #3 (permalink)
southmike
well there is actually 3 types- sp diesels electrical version, a regulated version like itp's,
and a valve like dieselsites.there is a lil back and forth, about which is best.
dieselsites works just fine. the boost leaks are un-noticable, and have no effect on performance..were talking about needle point hole leak. never heard any problems with them.
the itp seems to be slightly more popular. But it has its qwarks too, most of the problems are, user error install problems. at least a half dozen or more have been sent back...really because the user got the ajustment so far out of wack, and needed dennis to reset it. so if you get that one and order on the phone I would go a head and ask him how much you should adjust it , and when . they seem to work fine when set up correctly and not toyed with.
sp diesels has the same one user had no luck with it and bashed it with a hammer, personally i would have returned it for a replacement, or a refund...others use them fine.
kinda boils down to price, and prefernce.
I would wait to add it, to a list as they are small and can be shipped easy with other things.
as far as preference that is an individual user opinion.
early 99 f350 4x4 crew cab
work in progress
southmike is offline   Reply With Quote
