Diesel Forum - TheDieselStop.com - View Single Post - Rearview mirror removal?
Old 04-05-2008, 08:36 PM   #3 (permalink)
RRose
ok.... so I figured it out.... this mirror doesn't have the traditional release mechanism.... you put the screw driver in from the top and pry the mirror out toward you.... it has spring loaded clips on its side that hold it on....
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline   Reply With Quote
