Diesel Forum - TheDieselStop.com - View Single Post - 2001 Excursion Vegistroke Questions
Old 04-07-2008, 06:32 PM   #27 (permalink)
airfooter
airfooter's Avatar
Originally Posted by greasy_Exc View Post
The GC kit uses a 5 micron filter under pressure. What is polishing? Should I use an inline filter fuel filter?
Jesse
Yes, your 'final' filter should be a FUEL filter. House water filters, etc are ok for some filtering - but your final pass should be at least 5 mic 'absolute'. Smaller is better. I have not used the bag filters and not sure how they are rated, but I'd still run a 5 or even 2 micron spin-on type filter LAST. Hey, if the others are doing their job - ya may never change it! Filter heads are $30ish dollars and I use a wix 10 mic on the truck (24006) and its a little over $5/ea.
Polishing is just a term for 'final filtering'. Usually to an 'absolute' micron rating. A 'nominal' rating can allow particles larger than that thru it...
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
airfooter is offline   Reply With Quote
