Diesel Forum - TheDieselStop.com - View Single Post - Seprentine belt - but what about the fan clutch wires?!
Old 04-10-2008, 01:08 PM   #34 (permalink)
Engine13
Yesterday myself and a friend took on the task of replacing the serpentine belt and replacing an idler pulley. I have the single alternator set-up so we did the work without cutting the shroud or removing the shroud, but we did remove the plastic wing above the shroud. The whole process was no easy task, particularly putting the belt back on. I read most of the posts about this topic, but there is very little tips given for putting the belt back on. I was wondering if anyone has any tips or tricks they used for the install? Where did you start at? Is it just that much easier to go ahead and remove the shroud?
Thanks,
John
2003 F350 6.0 PSD 4X4 SRW
Engine13 is offline   Reply With Quote
