Old 04-11-2008, 01:50 PM   #37 (permalink)
airfooter
airfooter's Avatar
Originally Posted by greasy_Exc View Post
I found out about a guy in Redding Ca at Roverhybrids.com, seems he is in the process of becoming an official DFA installer. At $400 bucks cheaper than my current installer guy (who claims PSD experiance) this guy has PSD conversions on his website, I think it might be worth the 3hr trip up to Redding... I finished (sort of) the gauge piller install today... Found out that my autometer trans temp gauge did not come with a sending unit (only after I started the install). Here is a question for you Excursion 7.3l people out there: I installed my boost gauge today (had to drill and tap) just after the turbo, on the y-pipe heading to the intercooler (passenger side of the "y"). I thought I had done something wrong, as when I started the truck--- nothing happened! (truck started, but no gauge reading). Not having time to mess with it, I left to run my errands... I found out that @ 2000 rpm I am getting about 5psi boost. This has to be wrong...right? My turbo sounds fine, I get the power I am supposed to get(?), did I do something wrong with the gauge install? I checked and doublechecked, no kinks, leaks, or anything else that would cause this to go funny. Now when I steped on it, it went all the way to 25psi...just for a second. I have the TM wastegate controller, just haven't installed it yet. Whats up with this?
You can get the temp sender at auto parts - about $10-12.
I spliced into the boost sensor hose and later used that splice to install the 'boost fooler' and used it for gauge tap.
5psi rolling down the road is normal and seeing a spike while yer in the throttle is normal. 25 psi is healthy for a slightly modded truck. Stockers usually only hit 16-17 psi......
I'm not cheap - I'm just BROKE!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, LSD, 4.10's NAPA 6637, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, Mobil 1 in trans, t-case & diffs, LUK clutch, Swamps single-shots!!! Vegistroke-inspired WVO system w/95,000 trouble-free miles! DP-Tuner F5 - stock-high idle-40t-60t-80e-100 - Lovin' it!! 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - F5, AIS, Frybrid/V3 SVO conversion that does 100mi/day. 30k flawless VO miles so far!
frybrid.com
airfooter is offline   Reply With Quote
