Diesel Forum - TheDieselStop.com - View Single Post - 2001 Excursion Vegistroke Questions
Old 04-11-2008, 05:17 PM   #38 (permalink)
greasy_Exc
My Photos: (20)
When I get my TM installed will this change the boost I see? I.E. instead of 5psi rolling down the road will it go higher? Or does the boost I see go up with more fuel (like a chip install or something)? As far as the Trans temp sending unit, I am a MORON... I didn't look hard enough at what I thought were just fitting adapters, sure enough the sending unit was right there... So now I have to pull the pillar off and run wires for this gauge... shouldn't be too hard. I have another thread talking about the TM install and someone said that NAPA should have "push clips" to use instead of the "e" clip that comes with the TM wastegate controller anyone know anything about this? Supposedly they are so much easier to install than the "e" clip, and you don't have to remove the turbo... Thanks for your help.
2001 Excursion 7.3l 131,270 mi
aFe Stage 2 Cold air intake
4" exhaust no kitty
Autometer Trans, EGT, WVO Fuel Level, and Boost gauges
4 pod A pillar
Turbo Master Wastegate Actuator
Vegistroke V3(Smells like angry Oil Shareholders...)
27 gal Custom Underbelly WVO Tank
Investigating:
DP Tune
Stand up against the pump! Switch to vegi, hybrid, solar or whatever people cannot use to regulate YOUR life!
greasy_Exc is offline   Reply With Quote
