Diesel Forum - TheDieselStop.com - View Single Post - 2001 Excursion Vegistroke Questions
Old 04-15-2008, 12:05 PM   #42 (permalink)
edoubleupvlx
I will be installing it myself. My tank is an underbelly on the drivers side next to the frame rail and the drive shaft, starting just behind the transfer case. Its 5 feet long 12 inches wide and 10 inches deep. It has two notchouts for the crossmemembers and the fuel lines that go around the forward crossmember. it has three baffles and a drain on the bottom. I used 5/8 aluminum tubing running the length and back on the bottom for the coolant tube. It has a 1 1/4 fill with a vent and 3/8 fuel in and out with a vertical marine sender. That should be around 30 gallons. I got the dual fill kit from golden fuel systems. My tank should be finished tomorrow. where are you filling your tank from? where did you get your tank? I looked all over before I decided to have mine built custom.
edoubleupvlx is offline   Reply With Quote
