Diesel Forum - TheDieselStop.com - View Single Post - Cost of building home on own lot
Old 04-21-2008, 07:13 PM   #9 (permalink)
short_stuff
Barrelhorses,
Also check in to SIP panels (structural Insulated panels). I checked them out last fall at one of the home shows, and I think that will be the route I go when I add the 900 foot addition to my lake house. Their price sheet for a 2560 sft house (sides and roof) shows $24900. And they can usually put the house together on your slab, on blocks, or basement walls, in about a day to 2 days (depending on how complex the floor plan is). SIP's are panels (up to 28 feet long) with a layer of Styrofoam sandwiched between 2 layers of OSB. So, you can get the ceilings already insulated at an R-28 or R-34 insulation rating. A 10 inch thick insulated floor has an R-64 rating. If you're intertested, check out Precision Panel - Advanced Framing System - SIPS - Structural Insulated Panels, and the floor plans at New Frontier Building Systems - SIP Kits, Hi-Velocity HVAC and HEPA Air Exchangers . I tore my old garage down over the weekend to make room for the new addition, so I"m getting closer to "git'er done".
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline   Reply With Quote
