Are all you guys paying this much for houses????
When I left Boise ID in 2001 you could get new stick construction for $75 sf turn key construction.
Going off straight numbers @75 a sf a 2000sf home is 150K. If you are a modest person I think you can come in close to that.
I just got done doing a basement this last summer. It was 15K for 800sf with extra 2" on wall thickness.
If you are willing to do work yourself, or buy a kit house you can save serious amounts of labor. Look into having someone frame it out and you finish the inside?
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
Reason: spelling
