can you post a pic of the tank. I just got mine back yesterday and will try to post a pic. My install of the v3 is 90% done. It was a straight forward install that went fast. I made a mistake when I put my switches in the dash. My excursion didnt have enough flat on the dash and the switch bezel does not fit perfectly. Im going to replace the dash piece and move the switches to the fuse cover. Now I have to bolt up the tank and run the hoses and then Im done. The dual fill went in nicely with some cutting. I have to paint it and then put it back. How much was your tank. Mine was $500.00 wholesale price thru my friends marine business. It was suppose to be 650.00 after tax. Now I have to drive around to get the fittings and bolts and rubber mounts for the tank and drill holes. Im looking for an isspro black, black, red pointer fuel level gauge and figure out if it will work with my sender. I also have to figure out what to do with both tank vents.
01 excursion, 4x4 3" lift 18" wheels, MBRP turbo back ,Napa intake,edge evolution, vegistroke system w/custom tank
