Thread: Beefing up FAQ
Old 05-01-2008, 08:51 PM   #9 (permalink)
justincase64
Cheap Mods
HFCM upgrade- HFCM upgrade
maglite clips- Maglite Clips
zoodad-
longer wiper blades- 24" Wipers
hibeam+fog (steve racer?)- Hibeam+Fog (Steve Racer)
Foglight upgrade- Foglight 9005 upgrade
harpoon- Harpoon
fumoto w/ nipple- F-111N Fumoto oil drain valve F-111N
tubing doors-
excursion sound panel- Excursion Sound Panel
excursion wheel well panel- Excursion Wheel Well Panel
high idle mod- High Idle
2Low mod-
TC lockup, TC light mod-
warn hubs-
08 diff cover-
front door marker- Front Door Marker
marnico plug mod-
Block heating cord instructions- Heater Cord Install
AIC- AIC
Acetone Badges- Apply acetone to remove the black paint on the factory badges and make them chrome.
Snowman Mod-
Backup Lights- Backup Lights
How to Control Mirror Heat-How to control Mirror heat;Here are the directions for hooking up the mirror heat to an upfitter switch. It is easiest to remove the four bolts that hold in the fuse panel and pull it forward. The wire you want is on the middle connector, on the back of the fuse panel. It is on the left side of the connector, second from the bottom. It is green with a purple strip. You can double check by hooking up a test light or meter and turning the ignition on. It will then show hot(12v). Next remove the fuse for the mirror heat and retest. If it is cold you know you have the right one. Cut the wire about an 1 1/2 inches from the fuse panel and strip both ends. Put a connector(bullet or butt) on the end coming from the wire harness and attach the other end to the upfitter wire one or two. I then took the other end coming out of the fuse box and attached a female bullet connector. This gives me another fused ignition on power source.
Maintainence Tutorials
rotate hubs-
Change Oil- Changing Oil
change coolant- Flushing Cooling System
flush trans- Flush 5110 Trans
grease slipjoint- Grease slipjoint
repair door actuators-
EGR Cleaning- EGR Cleaning
brake tutorial- Replace Brake Pads and Rotors
brake break in-
Brake Rotor Break in (bedding)
flush brakes- Brake Flush
ball joint install (use 1/4 90degree zerk fitting)- Ball Joint Replacement
Fuel filter change- Change Fuel Filter
Turbo reconditioning- Turbo Reconditioning
How to determine what air pressure- Proper Tire Infaltion
Door Panel Removal- - Door Panel Removal
Changing Air Filter- Changing Air Filter
Filter Interchange Numbers
Oil Filter
IH- 1840752C91
Fram- CH9549 ($17 at walmart)
Motorcraft- FL-2016
Ford- 3C3Z6731AA
Napa- FIL-7312
Racor- PFL2016
Wix- 57314
Baldwin- P7235
Amsoil- EAO88
Fuel Filter
IH- 1847170C93 (new), 1847170C92 (old)
Motorcraft- FD-4604 (FD4604 $49 at advanced auto)
Napa- FIL-3899
Racor- PFF4604
Wix- 33599
Baldwin- PF7812
Amsoil- FFK60
Transmission Filter
Internal
Motorcraft- FT144
Ford- 3C3Z7A098AA
External
Motocraft- FT145
Ford- 3C3Z7B155BA
Air Filter
Motorcraft- FA-1778
Donaldson- P603577
Napa- FIL-2731
Wix- 42731
Technical Articles
Filters- Filters
6.0 Tools
Oil/Fuel filter wrench- Oil/Fuel Filter Socket
Snap on oil/fuel filter wrench- S3624, Socket, Filter Flip, 24 and 36mm, 3/8" square drive
2004 6.0 F250 CC shortbed 4x4, 3.73's, zoodad, steve racer mod, harpooned tank, 30% 3m on fronts, lineX bedliner, DR leveling, bilsteins, 315/75 nitto terra grapplers, navi, code reader from dfuser, on order: cryo'd rotors, hawk pads, snuglid sl, nchornet ccv, ate super blue fluid
justincase64 is offline   Reply With Quote
