Diesel Forum - TheDieselStop.com - View Single Post - Diesel Secret?
Thread: Diesel Secret?
Old 05-02-2008, 10:02 AM   #6 (permalink)
DIESELDUTTON
DIESELDUTTON's Avatar
Originally Posted by JohnMx854 View Post
I just bought the DSE system and as far as i am concerned it is a bunch of crap. I ran about 60 gallons through my truck and now every filter got clogged and my injectors are very dirty. I took the fuel pump out of the tank and took a peek inside and the hole tank was covered in a white grease. Im gonna try to modify my mixture and hopefully it works this time around.
1997 F350 Powerstroke,reg cab, 4x4, 142,000 miles
If this was on your 97 in your sig they dont have a pump in the tank unless you installed a pump in both tanks. Do you have another truck, post 99 that has a single tank, now that I think about it they have a frame mounted pump Good luck with that
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline   Reply With Quote
