Originally Posted by Mark Kovalsky
You can. I am in my 4R100, but only because I still have enough MERCON in my garage from one more change.
DO NOT use DexV!!!!!! That will most likely kill a Ford transmission. DexV is a GM fluid, who knows what it will do in a Ford?
Does that mean you will use the new Mercon V after you use up your Mercon, Mark? Are you have confident that the new Mercon V will not cause any damage to the 4R100?
2003 7.3 SD, CC, 4x4 with FX4 package, white and 100% stock
