- Open the hood and reach in along the fender where the factory side vent is. Squeeze the metal clips together one at a time while pushing the clip away from the truck (out of the slot). You can pull on the vent at the same time to help pop the vent off. Don't pull to hard and break the prongs holding the clips.
- With the vent removed place it face down on a cloth. With a small flat head screwdriver carefully remove the 2 push nuts in the middle of the vent that are holding the grill section of the vent to the outer chrome shell. They are approx. ¼ inch in diameter and are between the top and bottom grille section. Put the screwdriver under the clip and slowly work around the stub lifting a little at a time until you get it off the stub.
 2008 F-250 Lariat, C/C, 4x4, SRW, SB, 6.4L
8" Fabtech Coil-Over 4 Link Lift, 40x15.50R20 Toyo M/T, 20x11 MKW Wheels, AMP Research Steps, BADP 165hp Tune, Jimmi Jammers, Dynamatted, Pioneer Avic Z3, 6 Diamond Audio Door Speakers, 3 Diamond Shallow Mount 10s, and 2 Diamond Amps, 152db Train Horns, Limo Tint, Husky Floor Liners, Spray-in Bed Liner, Bushwacker Pocket Flares, Recon LED Smoked Mirror and 3rd Brake Lights...
Have owned:
2000 F-250 XLT C/C 2wd SRW SB 7.3L
2001 F-250 Lariet C/C 4x4 SRW SB 7.3L
2003 F-250 XLT C/C FX4 SRW SB 6.0L
2002 F-250 XLT C/C 4x4 SRW SB 7.3L
2005 F-350 XLT Sport C/C FX4 SRW SB 6.0L
