DSE yes it works if you don't rush the process.
If you ask 50 people what they think of DSE you will get bad and good results. The ones with good oil and let it settle and filter the right way they have good positive results. The ones with the bad oil and dont let it settle and rush things have horror stories.
If a doctor tells you you are sick and will die I bet you will go to another doctor before accepting that. There are just to many things that can go wrong if you dont take time and prepare for what you want.
The first few mixes I did was experimental and a learning process.
Now I am just refining my setup but have had good results with DSE.
The manual is a great starting point and you can improve many things as you learn from your mistakes.
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60  , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps, Tony Wildman  Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
