Diesel Forum - TheDieselStop.com - View Single Post - 2001 Excursion Vegistroke Questions
Old 05-08-2008, 12:07 AM   #50 (permalink)
edoubleupvlx
I just finished tonight and it runs great. Ive been working alot and couldnt find time to work on my truck very much. The hardest part was getting the tank bolted up. the tank was blocking access to the bolts so I had to drill and tap plate steel and thread the bolts thru the frame into the threaded plates. It worked great and then I had to fab up brackets for the crossmember mounts because you cant get behind there very well either. Vegistroke did a great job on this kit and I only made one call to jason who picked up right away and answered my question and then it was running. Let me know if you still need info on the install. I had no Idea the tank was going to get so hot.
2001 Excursion Vegistroke Questions-install.jpg   2001 Excursion Vegistroke Questions-plate.jpg   2001 Excursion Vegistroke Questions-myrig.jpg   2001 Excursion Vegistroke Questions-bolted.jpg   2001 Excursion Vegistroke Questions-crossbolt.jpg
01 excursion, 4x4 3" lift 18" wheels, MBRP turbo back ,Napa intake,edge evolution, vegistroke system w/custom tank
edoubleupvlx is offline   Reply With Quote
