Originally Posted by TNDEERHUNTER
Yeh guys I did the Ic foil wrap mod and I was wondering anyone else did it how did they get all the old insulation off the pipe. Thanks
i did this mod to my truck you just peel it off as best as you can then i used 2 cans of brake cleaner and a wire brush to get the rest of off i ended up polishing both tubes when i was done hope this helps you
02 f250 4x4 w/ a 7.3 it has a 4in exhaust from the turbo back, s&b cold air intake, hyper junk stage 3 programmer, idm mod, foil delete mod w/ polished boost tubes, fuel cross over, hpx line, torque converter lock up mod, cvc mod, magnatec trans pan 4qrt over, 6in lift w/ 315 75 r16 bfg all terrains.
