Check the slip ring contacts in the steering wheel and the wiring associated with it. The horn and cruise use this to send the voltage to activate the horn and cruise. It may not be making proper contact due to wear or dirt or the grounding may not be good. I don't have a wiring diagram for your year to tell you which wire to check, but the steering wheel bundle doesn't have that many in it.
Good luck.
