Diesel Forum - TheDieselStop.com - View Single Post - How Do You Adjust Tow Command?
Old 05-10-2008, 01:50 PM   #2 (permalink)
ritschner
ritschner's Avatar
Send a message via AIM to ritschner
I set mine on 7.0 for the 2000lb empty utility trailer, 8.0 when it has the 4500lb tractor on it, 8.5 for the 15,500lb fifth wheel, and 9.0 when I had the fifth wheel with Jet Skies in tow. I believe the setting is voltage only and will apply the same amount of braking per axle on a given setting, regardless of the number of axles. The other factor that will affect braking, is the brake adjustment being correct on the trailer axles.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline   Reply With Quote
