If your storage lot is gravel (if not, find a gravel area), next time you hook up to the trailer try this. Get going about 15 MPH, then slide the Tow Command lever all the way to the left for just a second. If your trailer brakes don't lock up, adjust it up .5 at a time until they do. Mine works best at 8.5 for my 5er.
Also, keep in mind that it may take a couple thousand miles for your trailer brakes to "burn in" before they WILL lock up. Then you might need to check the actual adjustment on each brake.
Mark
2011 F-350 DRW 4X4 Lariat - pic
Pulling a 2010 Sierra 355QBQ 5er
Sold- '08 F-350 - pic
Sold - 2008 Jayco Eagle 5er - pic
Sold - '01 F-350 - pic
