Originally Posted by MarkMCM
43,000 miles, I tow 8k about 500 miles per month.
Today as I was driving it felt as though someone had applied the brakes. It would do this for a few seconds and then be fine for a few seconds and repeat. Trans has never been hot and seems to work ok in 2nd.
1) Ideas?
2) Should I take it to the dealer or look for a trans specialist in the D/FW Texas area?
That's the diode. I know it because that is what I had before. Your trans is TOAST. I'd recommend you can 1-870-422-3673 and they will ship it to where you want and your trans problems will be over.
Ford has a trans if you are not going to modify the truck otherwise, the warranty is void at the worst case scenario
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system and Van Turbo. Bilstein Shocks with U code front and A code Rear.
