Thanks for the tip on the weakness of the horns. I received the Colibert parts and it took all of 10 minutes to remove bumper, bolt loops on and reinstall bumper. My buddy is going to weld a 1 1/2" heavy wall tube between the two horns the next time I go over to his place. Good idea about the receiver. At least now I can get some support up there.
1997 F350 Crew Cab 4x4, AT, 4.10, drivetrain is all stock. Toyo Open Country A/T 285/65-18 10-ply on Allied Renegade wheels. Snugtop shell. TYMAR Intake. Coated H-Max DP with 4" exhaust. Donaldson resonator and Cat had to be put to sleep. Just turned 49,000 original miles!!!! Best addition-Wildman chip-(just added) Phantom II gauges. Sonnax valve w/ Tri-C springs and Royal Purple in the trans. B&W turnover with Companion 5th wheel. SuperSprings installed.
