thanks for the info... solar panel would work to keep batteries up when in storage... did you pigtail to both batteries or do you have to switch? the batteries are only couple years old as is the trailer. i do have a small generator...but i don't like to run it unless i'm around...usually busy hunting or fishing and not spending much time at the rv....so i want to be sure the batteries are at full charge before i leave home...long trips to the site isn't a problem...but hauling less than 100mi. doesn't seem to get the batteries fully charged.
97 f250 4x4 ext cab tymar filter e4od 410 ts chip dp and 4" exhaust system
