Originally Posted by goodolcountryboy83
Hey guys. I have a 2005 250 4x4. Has 89,000 miles on it. Completely stock. Went to crank it this morning and cranked fine. Let it warm up like usual, but I noticed white smoke coming out the tail pipe, I have NO turbo psi, and at around 1500 rpms it shutters. I cant even drive it. So I have white smoke, no turbo boost ( well if I rev it up to around 2000 rpms the gauge moves up to around 1 psi) It idles fine but once I put it in gear and start giving it some throttle it shutters and white smoke is following me around. I need some advice as to what it is, because it is my primary vehicle and need to fix it this afternoon if possible. I can fix most any of the minor things but if its something to do with injectors or something covered under warranty I'll take it in.
thanks for any help..............
How frequently do you drive it? It might be a frozen set of turbo vanes.
OMC
