julyer
I put a switch in the circuit from the trailer's built in charger so that I could choose to charge from either source. The charging systems are connected to charge both batteries. The batteries are wired in parallel to provide 12vdc with a lot of amperage capacity.
I forgot to use the switch one time and found that both the solar charge controller and the built-in charger, caused no ill effects to the batteries. I have left both charging systems connected to the batteries for two years now and everything is still OK.
2001 F250 SC 4X4 Blue PSD Auto, Cody Gooseneck Hitch, Rancho Shocks and Steering Stabilzer, Tekonsha Prodigy Controller, Garmin Streetpilot 2610 GPS, Walker BTM, 285/75R/16E, Western Diesel Trans-Pyro-Boost, Pillar Mount, Painless fuse panel, In-tank and Pre-pump mods, Slotted Rear Rotors, Slotted and Cross Drilled Front Rotors, Fumoto Valve, Zoodad Mod, Transfer Flow 46 gal tank, Mag-Hytec Differential Cover, Electric Tailgate Lock, IAH Deleted, Coolant Filter, DP-Tuner 80 hp PCM, CCV Mod, 203 Thermostat, Ford AIS Air Filter
