If you want to do it on straight fuel alone, you'll need a set of Stage 2 injectors. With the right mods, they will go 400hp at the rear wheels. The other mods you would need are an air intake, tuner with custom tunes (to take advantage of the big injectors), and an after market turbo to burn all the extra fuel. Mods you might need are a 17* High Pressure Oil Pump and a Fuel System. Mods like Propane and water methanol will get you there quicker, but they're temporary power. My truck with the mods listed below is probably somewhere between 350-375 at the rear wheels. I still have the stock turbo, fuel system, and 15* pump (although my pump holds pressure fine).
Justin
Visit the Middle Tennessee Pullers Association at http://www.midtnpullers.com
1997 F-250 Power Stroke - 200k
Bean's Stage II's
DP F-6 Tuner
Tymar Intake
Southbend Con OFE
Grand Rock 5" Stacks
2005 F-350 Power Stroke (company work truck) - 150k
ARP Studs
