Okay... i have two batteries hooked up in parallel. all feeds hot and neg. from trailer are connected to one battery. the other battery just feeds parallel to first battery and both are end to end in front of trailer.... so, if i'm understanding your method of charging...i would hook up from the charger -v to -ve on one battery and +v to +ve on the other battery and both batteries will take the charge? also thanks for the info on equalizing the batteries.
97 f250 4x4 ext cab tymar filter e4od 410 ts chip dp and 4" exhaust system
