Diesel Forum - TheDieselStop.com - View Single Post - Bad mileage on '05 6.0
Old 05-18-2008, 10:50 PM   #8 (permalink)
bismic
Here is some more info on poor fuel economy:
6.0/6.4 Fuel Economy:
Ford vehicles equipped with the 6.0 PowerStroke diesel are not rated for fuel economy by the EPA. If economy is in question, a boost test should be performed. If boost reaches 22-25 PSI in third gear, wide open throttle under load, then the engine is operating normally and no economy related repairs need to be performed. If not in specs, then the engine will need to be diagnosed--check sensor reading, VGT and EGR operation, fuel pressure and quality, crankcase pressure, intake or exhaust restriction, exhaust or CAC leaks.
Fuel economy will be affected by many factors, including: excessive idle time (one hour equals approximately 33 miles of driving), fuel quality and blend, ambient temperature, driving habits, vehicle use, towing, loads, add-on accessories. Broadcast Message 1271, 4450, 6989
Mark
bismic is offline   Reply With Quote
