Diesel Forum - TheDieselStop.com - View Single Post - 01 chevy 6.5 turbo diesel smoke
Old 05-23-2008, 10:45 AM   #4 (permalink)
MarkEkberg
MarkEkberg's Avatar
My Photos: (13)
Smoke at idle could be from many sources.
1. Bad turbo seals allowing incomplete burn of the oil.
2. Too much blow by, but I think that should be seen under power as well.
3. CCV letting too much oil out of it.
4. It could be over fueling at idle as well.
I think in 01 there was a option for the maxi or 6.5, but people are right you need to find out what motor it is.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline   Reply With Quote
