If you are a private resident over weight no one will ever know about it. I have yet to see any proof that DOT will pull private people and weigh them.
If you are a commercial rig hauling anything you will be parked and fined. Fines could range from 150-1500 depending on how obnoxious the DOT officer and you are.
