Diesel Forum - TheDieselStop.com - View Single Post - WMO Info
Thread: WMO Info
Old 06-04-2008, 07:14 AM   #7 (permalink)
jski55
Originally Posted by LunaTech View Post
I filter straight oil, add it to the truck tank and then go fill the rest up with diesel. I do love having 2 tanks. It gets mixed really well when I fill the tank.
Jeff
It helps when you are collecting oil to mix it with diesel or whatever you are going to cut it with to do that before you filter. That speeds up the filtering process. Keep in mind that i have run 100% wmo but I used a two tank setup for that testing phase. Meaning i started and ended on straight diesel but switched to pure highly filtered wmo when i was warmed up. Welcome to WMO use: REcycling at its best. Saves pollution from discarded motor oil, saves diesel for everyone and saves you a little money in the process.
AS far as the naysayers...they are entitled to their opinions. And those opinions are usually based on heresay not experience.
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline   Reply With Quote
