Originally Posted by XRACER
Yes. At 250 degrees the tranny settles into second gear and won't budge.
That is stage 1. But you can use 1st if you shift manually.
If the temperature continues to climb, engine power will then be reduced to about 50%. At least on the V10s.
That happened to me only once. 24,000 combined up a 12% grade. I got stuck behind a bus, and the slower speed really made the trans heat up (almost no airflow at 20 mph). I also did not think to remove my grill insert before starting the climb, and that insert blocked about 50% of the air.
