Originally Posted by kjk
i think i might have a boost leak. i don't know anything else it could be (ofcourse you can always learn something new). my boost gauge doesn't register anything unless i put my heavy foot down. yesterday it was getting 15lbs max. today i disconnected the wastegate and now it maxes out at 18 lbs. it still shows not boost cruzing down the road at 50mph. i have checked the boost line from the MAP vacuum line to the gauge and it isn't kinked. is there a different or better place to tap into a vacuum line? Seriously i'm lost and need help to figure this out. Thanks in advance
Bob Riley at the DIESELSITE.com used to sell a lboost leak checker. It is around 60 bucks. You undo the intake to turbo hose and put in this large leak checker plug with fittings that clamps off the supply end. Then you put low pressure regulated air from an air compressor on the fittings pressurizing the turbo and intercooler system. A hose leak will be evident from the hissing sound and pretty easy to find with the engine off. Leaks are pretty common with the stock FORD silicon boots. If I am in OD cruzing unloaded at 50 MPH I get 2 PSI boost. That is pretty low RPM and not much fuel is getting burned. So if you are reading no boost then you probably do have a leak. What temp does your pyro run then? 106
