Originally Posted by dieselfordguy
I'm sorry to beat a dead hourse - but Do I need to use a hydrometer? What is it for?
You really only need to use it if you are making BioDiesel. It is one of the tests used to validate your veg oil conversion.
I believe he was using it to verify that his blend isn't to thick. The older diesels (with a high pressure fuel pump) cannot handle thick fuel. The newer Powerstroke only has a lift fuel pump and then the injector does the rest. If the thick can get through the lift pump than the injector will never see the thick because the head will heat it up to 200 plus degrees.
I still do not understand why the powerstroke is not considered a common rail system. Common rail shared on each head.
Best Regards,
2K Excursion Ltd Burg Auto, 175k
2K F350 DRW Lariat 6spd CC White/tan, 248k
Late 98 (04/98), WHT F250 Std Cab 6 spd, 356k miles
Engine Coolant Filter, fuel and hpop crossover Hutch in tank mod
open ccv
6637 air filter
looks like a muffler (looks can be deceiving)
DP stock, 80T, 80E, 140 Extreme (normally in extreme and still get 19 plus mpg)
fuel gauge on bowl and shimmed return
$$$ Penny glow plugs at AutoZone
Pics
