There are flex joints in the turbo up pipes similar to what the 6.0L has. The 6.0L has has a problem with them splitting causing a loud exhaust noise. I have seen this only once on a 6.4L so far and have not heard of too many instances. On the one I repaired I chose not to remove the cab but I did pull the transmission. Some techs don't think either is necessary but after the troubles I experienced I wished I had.
Ford Master Diesel Technician
