Po4o4 P1335
The closed position must be learned after cleaning the valve. You can set codes if the closed position is not relearned. The keep alive memory must be wiped out and then the the self test must be ran. You might set Po4o4 or P1335 if the new close position does not match the ECM's stored position.
