Diesel Forum - TheDieselStop.com - View Single Post - 01 chevy 6.5 turbo diesel smoke
Old 06-24-2008, 12:14 PM   #7 (permalink)
daytondiesel
Originally Posted by johnnyturbo741 View Post
its burning oil if its blue and if its a light grey or white its water or coolant
if it's an 01 then it's a D-Max, if the truck has less then 200,000 miles on it check the fuel in the oil, when you find it. then take to a stealership and get a new set of injectors. this is the poor filtration taking out the injectors by ball seat erosion. you can also use your scantool and do injector kill test to find a leaking injector, also try cylinder balance rates. this will show a bad injector.
Jay
2003 F-350 4x4 CCLB QUADZILLA FCHIP W/COMMANDER, BD TORQUE CONVERTOR AND ACC. BODY, AMSOIL FLUIDS, MAGNA FLOW DUAL EXHAUST, BULLYDOG AIR BOX W/AMSOIL FILTER
daytondiesel is offline   Reply With Quote
