Diesel Forum - TheDieselStop.com - View Single Post - Excursion Vegistroke install, Full story
Old 06-25-2008, 02:36 AM   #49 (permalink)
greasy_Exc
My Photos: (20)
Wow... apparently everyone around william is an incompetant stooge, its a wonder you haven't taken over the world. "Your" tank maker Brian is a brilliant fabricator, and even though his sole income relies on the scraps you feed him he manages to get by. As far as Shane from Rover Hybrids, that man has forgotten more about diesel mechanics and vegi conversion than most people learn in a lifetime. Face it man, you are a crap buisness man, you came off as shady and unreliable. Instead of getting upset, maybe you should look at what the CUSTOMER found wrong with your buisness practices and adjust accordinly ...or don't, either way the way you deal with people is up to you, I was completely satisfied with the service I recieved, and have since refered several people to that man. Customer satisfaction is commencerate with high referal rates, good luck with your future endeavors.
Jesse
2001 Excursion 7.3l 131,270 mi
aFe Stage 2 Cold air intake
4" exhaust no kitty
Autometer Trans, EGT, WVO Fuel Level, and Boost gauges
4 pod A pillar
Turbo Master Wastegate Actuator
Vegistroke V3(Smells like angry Oil Shareholders...)
27 gal Custom Underbelly WVO Tank
Investigating:
DP Tune
Stand up against the pump! Switch to vegi, hybrid, solar or whatever people cannot use to regulate YOUR life!
greasy_Exc is offline   Reply With Quote
