Originally Posted by CMB430
That is why I like it to idle for a few minutes (3-7 min) before pulling out. I also, even now when it is 90 degrees, let it idle for at least 1 min before turning it off. That is with no load. I average 16.8 mpg when it is above 50 deg, but when it is below I get closer to 14.5 mpg. So I assume you understand how idling high when it is Jan weather does nothing for mileage. There must be a fix for it...and I will find it.
Idling the engine does not do much to warm up the engine. If anything, it exacerbates the types of conditions that Dr. Evil was talking about above.
The fix is not to let it idle for so long.
Also, you don't need to let it idle for extended periods before shutting off. The only time that i would recommend this is when you have been towing a heavy load at high speeds.
