You are reading the guide correctly. The F250 is better suited to pulling a travel trailer than pulling a 5th wheel as a TT only puts about 10% of its weight onto the truck while 5th wheel put about 20%.
For example, you can pull a TT of 11,000 lbs GVWR and it will put 1,100 lbs on to the truck hitch and have a trailer axle weight (the towing weight) of 9900 lbs.
But a 5th wheel of 11,000 gvrw would put 2,200 lbs of pin weight onto the truck and have a trailer axle weight (towing weight) of 8,800 lbs. But the 2,200 would put your truck over its GVWR.
John
99 F350 PSD CC DRW, BD Tranny, Fan driven tranny cooler, exhaust brake, tranny temp gauge
Titanium 29/34 Fifthwheel
HiJack 21k 4way hitch
