Diesel Forum - TheDieselStop.com - View Single Post - Intake systems
Thread: Intake systems
Old 07-18-2008, 10:53 AM   #3 (permalink)
bigtruck311
Originally Posted by HeMiSlAyEr View Post
The best intake is the stock one. For perfomance and reliability it can't be beat. The only reason to get an aftermarket intake is if you have or have plans to get a larger turbo or injectors.
i have to disagree, stock pulling a small load (9k) it will pull the filter minder in all the way pulling hills, with no load you get on it it will pull it in half way, that is alot fo restriction in the stock intake, switched to S&B and pulling larger loads (15k) up the same hills and the filter minder doesnt budge, plus getting alittle better MPG .4-.5 or so. so for these trucks S&B cant be beat IMO
08 F-250 Black FX4 Every option
SCT 158 HP TUNE DPF Delet
S&B Intake
RBP Exuast
Straight pipe from DP Back
8" Fabtech lift
38"15.5"20 baya claws on rockstars
Rize traction bars
rize duel stabilizer
fox res. racing shocks all corners
bigtruck311 is offline   Reply With Quote
