Originally Posted by thecougar
I must be missing something. How do you know if the filter minder is moving while you are driving? If you are pulling a load I would think you are in the cab rather than under the hood.
Does Edge Insight or similar display this info?
Because it locks into place, so you can check it visually, and you have to press a button to reset it . . . what use would it be if you had to watch it while pulling?
