Biofumes,
if you look in the towing forum (where we are now) and find the heading (towing a gooseneck with my Excursion) you can see what I just pulled from Tn. to SoCal. It has a 3.5 donahue lift and 35" toyo open country mud terrian tires and still has the factory 3:73 gear ratio.
I did notice alot of the low end torque was gone with the lift and tires, but I then put one of Jodys DP tuners on the truck, and it woke it back up to a respectable towing machine. I pulled that set of double trailer 2200 miles and got a hand calculated 9.6 MPG most towing was done at 65 MPH.
I am also in the process of taking the Excursion up another 3-4 inches so that I can put some 37's on it and I will fork out the 1800.00 to re-gear the truck so it has its low end torque back.
Also, I will recomend you put a good tuner, exhaust and intake on to help improve the MPG.
2003 BLACK Excursion Limited 7.3 4x4 w/DVD entertainment center, rear captians chairs, 3.73 limited slip. 4" MBRB Stainless Exhaust, AFE stage II intake, DP F5 Tuner, 4.5" Donahue lift, Rolling on 18" Jesse James Lawless 8's wrapped by 35" Toyo Open Country Mud Terains and airbags, Prodigy brake controller.
2002 BLUE F350 XLT 7.3 4x4 Crew Cab short box, BTS Tranny, 6.0 tranny cooler, 4" Silverline Stainless exhaust, S&B intake, DP F6 Tuner with 9 tunes. Line X, B&W turnover ball, Prodigy brake controller.
1968 Chevy C-10 Short Bed PRO-STREET 500+CI BBC
1991 Honda CRX-SI (Black Also)
2002 John Deere Gator Diesel 6X6
2003 Limited edition Cannondale Cannibal- With colors that woulnt run, RED, WHITE and BLUE #0000016
Multiple 1969 Camaro Convertible Indy Pace Cars (one Documented Festival Car)
1-1972 El Camino SS (Pro Touring) Under construction.
