Im sure someone will correct me if Im wrong, but those tires (305/55/20) are darn close (if not over?) to 35 already. Stock 20 inch rims came with 34s on them. As long as the backspacing is right, you should have no problem.
07 F350 XL FX4 std cab 8' bed
4" MBRP turbo back straight piped
47 gal transfer tank
Warn 16.5 ti 16,500 lb winch, semi hidden winch mount
Skyjacker 2.5 inch level
305/65/17 BFG AT on black 17x9 ProComp 7005
Recon White Lighting
Alpine head unit, 4 channel MTX Blue Thunder amp, Polk component MOMOs up front, Infinity Refrence in back, Alpine MRP450 powering 10" Kicker CompVR
