This is a known problem at Ford.
Message center displaying "Wiring Fault On Trailer":
This may occur due to water intrusion/corrosion in the trailer connector socket or the connector behind the socket. If corrosion is present, replace the socket and harness and lube with silicone dielectric grease. If there are no signs of water, perform normal diagnosis. Broadcast Message 7052, 7108.
As soon as I got my truck, I pulled the wiring just to check. It was fine and there was a little bit of dielectric in there. I loaded it up. No water gonna get in there now.
'08 F350 Lariat DRW CC LB Job 3 Black/Silver
towing a '07 Raptor 3712TS toyhauler
with a '02 Kawasaki Nomad Dresser in the garage
