thanks for the input guys....I looked at the denmans..seem pretty good. Will the stock weekend warrior chrome steel wheels take 80psi? I haven't had one of the tires off the rim to check. I will do some research and let you know what i come up with. Yes i know 16's are the way to go but DAYHUUMM..the cost! the General Ameri-stars *SP* that were on there have a rating of 2350lbs or so...isnt' that pretty good? they did crack..but i've had the trailer in the sun for five years..no blowouts.....or should i still go with what you guys are recommending?
2002 F350 Lariat CC SRW 4x4 LB , Shadow Gray, Edge 4.5" w/ dual bilsteins up front/ Toyo Open Country M/T 315-75-16. Stock Motor 7.3, dual alts / 3 guage pillar pod, Auto Meter/ 5" turbo back magnaflow exhaust w/Aeroturbine muffler & 6" Jardine tip/ Husky 24k 5th wheel / Air Lift Bags.
John Wood Transmission / DP tuner / 08' rear diff cover
2005 40' Weekend Warrior 5er, SLC 3905
1977 Tahiti 21' / Berkeley Jet Daycruiser/ 455 Olds.
2000 Sandcars Unlimited / Turbo VW 2275
1988 Ford Thunderbird Turbocoupe 2.3
