That is why safety glasses should be worn, battery might explode. You can take a test light between the cable and the battery terminal and see if it lights and goes out, or stays dim. Anything other than going out indicates a constant drain on the battery. I have found that the test light may stay on dim due to the radio clock/memory battery, turn the radio on and off (test light still in circuit) and it should go out.
